will a bad battery stop the usb port from working?
When replacing the screen I was taking the battery out and made a mistake put a hole in the
battery. The did turn on before the battery died but it did not say that is was attached
to my computer when I pluged it in to the USB port on my PC. And of course when I check
the status of the phone it said that it was not charging. I figured that was because of the
damaged battery. But I l thought it aleast should be able to pass files to my PC though the
USB port but NO.
