bad z5 premium battery
MichaelHilliard
will a bad battery stop the usb port from working?
2 REPLIES 2
profile.country.PL.title
najodleglejszy
first, it's XZ Premium forum, not Z5 Premium.
second, what do you mean by "bad battery"?
MichaelHilliard
When replacing the screen I was taking the battery out and made a mistake put a hole in the
battery.  The did turn on before the battery died but it did not say that is was attached
to my computer when I pluged it in to the USB port on my PC.  And of course  when I check
the status of the phone it said that it was not charging.  I  figured that was because of the
damaged battery.  But I l thought it aleast should be able to pass files to my PC though the
USB port but NO.
