Backup problem Z5
Cs1575
Backup problem Z5
Hi
I got my sony xperia z5 a couple of weeks ago and encounter backup problem today. It was running as usual a week ago.
I went into Setting => Backup & reset => More => Manual backup
then try to change the "where to store file" to my gmail account but it wont sign in.  It kept on saying "online account not signed in".  Not matter what it wont let me change to online account, although the backup account section has my gmail signed in.
My gmail account is signed in in the accounts section as well and I cant find any other area that I need to sign in.
Could someone please help.   This is the first time it happen since I got my z5..
Thanks thanks...
63 REPLIES 63
Wodzu
Hi @Christofer I went to Settings -> Apps but I don't have in my [menu] the option to "show system". I only have options for sorting applications by size etc. On main screen I have three columns, "downloaded", "running", "all". In "all" I've found application called "Backup-Restore" but it does not have any data to clear out. It says 0,00 B. I haven't upgraded my phone because I don't want to lose stamina mode... Regards, Wodzu
Wodzu
@Bugmenotsony wrote:
And what apps did you deactivate under apps.?
Hi I have not deactivated any apps. I am not sure that Android update is relevant to the backup - restore service. It should backup my phone regardless of the android version, just like it is able to synchronize my mail, or google drive or any other services.
Christofer
Champion
@Wodzu Have you by any chance modified the phone's software in any way? That could cause this feature to stop working. Other than this I would suggest that you try a factory reset of the phone.
Wodzu
@Christofer I haven't modified anything in my phone.
Thanks for trying to help. Honestly I don't want to try restore default factory settings, it is too much hussle to put everything back to its place...
This is probably some trivial problem with some appon the phone, but I am not able to find it myself.. Slightly_frowning_Face
Tags (1)
rcam
I have a Z5 with last firmware (.253).
Twice reset the phone and 1 repair from Xperia Companion.
Backup and reset app do not work. In the mail account option, fails trying to sign. In the SD option, stops when reaches 50% of all options selected previously.
RR_227a
Did anyone ever get a resolution to this issue? My Sony Xperia Z5 has started doing it out of the blue, 3 mths ago.
Automatic back up won't work and is not signed in. Manual back up account is not signed in, nor will it sign in - experiences the same hang as mentioned above.
I have tried adjusting google account settings, logging out multiple times.. But still no luck. Any suggestions?
chewoo
Hi, I'm having the same issue!
Backup and Restore won't work with google account, it says 'Signing In' and hangs up there.
Also, when I try to backup to SD card, stuck at 50%.
I've done every solution fom page 1 to page 6, but no luck...
This started few days ago, until then everything was working fine, including automatic backup.
Sony guys, please fix this
Bhonder
I disabled applications's backup. In this way I can save the rest, at least.
It started to work bad since a couple of updates.
Maybe Sony should take a look at it.
chewoo
Can this be related to bootloader unlock process?
Jaz_Rio
My Z5 Compact with latest OS update android 6.0.1 isn't backing up manually to SD card nor automatically to Google account.
It's there solution Sony?
