Aux Cable audio output problem
PrinceCasanova
When Connecting a two black strip (3 pole) aux cable to sony xperia z3, the output doesnt work to an external speaker.
But when connecting a three black strip ( 4 pole ) aux cable to sony xperia z3, the output works to an external speaker..
Why is that ??
13 REPLIES 13
Rickard
Master
Sorry to hear that you have issues with AUX.
The phone also works with 3 pole so it's hard to say for sure what's wrong. It could perhaps be an issue with too low impedance of the speaker. What happens if you connect your phone with this cable to another stereo or receiver?
Bandolero
Why is that ??
I couldn't 100% confirm, but i believe is due to the noise cancelling feature on the z3 that has a 4 pole input in order for the headset to work.
Not sure if this will affect the external speaker output.
PrinceCasanova
It used to work with the cable...I have no idea why it suddenly stopped..
I have upgraded the mobile to 5.0...even after that it worked..
I used to connect my mobile to my sony xplod car audio using this 2 black ring cable..and it immediately used to start up the event in SMARTCONNECT....and start playing the music files on my car stereo...no problems at all..worked perfectly fine
Since yesterday it stopped working...
I took this cable and connected my mobile using this cable to my laptop audio...and it works perfectly fine..
Then I connected my mobile using this cable to an external standalone speaker....it doesnt work...
Rickard
Master
I suspect the issue here is the impedance of this external speaker. As i understand it, if the impedance is too low, the phone might not see that you're connecting it. You could perhaps try forcing the output to AUX using this app: https://play.google.com/store/apps/details?id=com.woodslink.android.wiredheadphoneroutingfix
If you have access to an AUX-cable with a volume control on the cable itself also try this and see if it works. A cable with a volume control on it will probably increase the impedance a little bit.
PrinceCasanova
yeah I installed the sountabout app and forced the output to "HEADSET" while plugging the same 2 rings aux cable from mobile to car sony explod player...and the music does get played in the car speakers... !!!!
Strange !!
Rickard
Master
Glad to hear that it works with the app Slightly_smiling_Face
This also indicates that the issue here is impedance of the AUX. I have heard that some Saab cars have this and seen discussions about it on some car related forums.
PrinceCasanova
The soundabout app isnt functioning too well....when activiated for media output to aux, it cuts off the call ringtones and notification tones..doesnt play them either on the phone speaker or the external speaker...
also u need to restart the phone to get it back to normal working once u disconnect the aux.
And now even my sony headset MH750 isnt recognized by the phone as an external head set....when connected..all output is on the phone speakers only..
Its really driving me crazy this phone !!!!
Rickard
Master
Sorry to hear that.
If you also have issues using a Sony headset like MH750 i recommend that you contact a service location to have your phone checked. For more information about how to submit your phone for repair and where, contact your local support team.
But first make sure it's not the soundabout app that's set to override the audio output.
But may i ask what car you have? I have heard of this issue with some Saab cars and from what i've been able to find on other forums, it's a known issue and it may also happen with phones from other brands.
Jake1
I have a problem with the aux aswell popping and crackling then the google voice command comes on aux issues worth both radio and car I put it down to the phone considering there is several of these forums with the same issue
