answering machine problem after z3 update to lollipop
ammarch
I updated my z3 dual to android 5 but now I cant record greeting for answering machine and says unfortunately , phone has stoped. If any one faced with problem like me? Any one can help me to solve it.
profile.country.RO.title
_alexdon_
Try settings-apps-all-phone,force stop and clear data.Restart.
alexdon
10 REPLIES 10
_alexdon_
alexdon
ammarch
Thank you Alexdon. The problem solved.
_alexdon_
Nice.
alexdon
negar
thank you so much.my problem solved.i was very depress:smileyyahoo:
stef_wein
Guys, please help me. Like you I tried to update my Z3 dual but it fail. So i can use my phone nor I know how to make it work again. It says "Sofware update fail. Make sure ..." it is conect to my pc but i can't turn it on. I don't  know if what you said will work "Try settings-apps-all-phone,force stop and clear data.Restart." i this case. And I don't know how to do it. HELP
HadiTak
Hello
I have a z3 dual. My answering machine don't work after upgrade to android 5. It force close app after record a greeting message. Why?!!!
profile.country.US.title
Qatrium
I just tried recording an Answering Maching Greeting message and it went OK on my Z3 Dual. I guess you might have a software bug/glitch. My advice is to do a backup of your personal data then proceed to a Factory reset, or phone repair via PC Companion.
_alexdon_
See the above solution before trying a software repair.
alexdon
sonyabraham22
solved
