I updated my z3 dual to android 5 but now I cant record greeting for answering machine and says unfortunately , phone has stoped. If any one faced with problem like me? Any one can help me to solve it.
Try settings-apps-all-phone,force stop and clear data.Restart.
Nice.
thank you so much.my problem solved.i was very depress:smileyyahoo:
Guys, please help me. Like you I tried to update my Z3 dual but it fail. So i can use my phone nor I know how to make it work again. It says "Sofware update fail. Make sure ..." it is conect to my pc but i can't turn it on. I don't know if what you said will work "Try settings-apps-all-phone,force stop and clear data.Restart." i this case. And I don't know how to do it. HELP
I just tried recording an Answering Maching Greeting message and it went OK on my Z3 Dual. I guess you might have a software bug/glitch. My advice is to do a backup of your personal data then proceed to a Factory reset, or phone repair via PC Companion.
See the above solution before trying a software repair.
solved
