Hey Guyz I have certain problems with my New Sony Xperia L C2104 :
1. The common problem the sony album goes blank when cache is cleared.
2. The Notification bar breaks in between some time.
3. The Notification led is white most of the time.
*4 . This one is the most important help me guyz ! When ever I open the walkman application the size of device memory automatically increases .i have tried reseting the phone to factory default but nothing worked.when I restore my phone the size of the device memory is 290mb approx but when I start the walkman app it automatically rises to 500mb or sometime 1.1gb..this problem is resulting in low device space.. Please rply as soon as possible.
the better solution for the album problem #1 problem....
goto settings->Apps->Allapps->album
here u can find the album app...
then just click on the app....
then app info appear...
clear data...in the storage menu....
then reopen the album again...problem will be solved..
guys ,me too facing album,walkman and camera problem.
now a brand new problem also occuring,that is battery discharging very quickly.
can anybody gime me suggestions plz
mobile screen goes white while opening camera
dude i am facing the same problem , i just cleared the cache and my album went blank . how to fix that ?? thanks
thnx man
i really worked
Go to settings>all apps>media storage and clear cache of media storage,then stop it and then restart the phone,maybe this will work.
Guys, I have a huge problem on the phone itself. This one is almost cause to me to smash it. It always restart the phone over and over again. Right after I try to synx. Don't know how to stop this. Even though I close already and on it didn't fix any problem. Please can someone tell me how to take care of this problem. It drain the battery every one and off occurred.
hi have a problem, with may xperia l c2105 after i using apps it heated and after i close anything, i cant reopen may phone and then it heated all the way and the battery got empty because of the heat .. after that i cant used it.. then i need to shut it down by putting again the battery to open it.. help me please what should i do..
Hi!
I am facing a couple of problems with my new Xperia L
1. Low Memory Space. it keeps showing memory space is low when i dont have much stored on the internal memory.
2. its keeps showing SD card unmounted/not detected every now and then.
3. LED light doesnt change or blink so many times upon receiving messages etc.
4. album goes blank on clearing cache.
5. Cant have any apps or games on the phone as the memory space goes low.
basically it is just a box now to make/ receive calls or message. dint expect sony Xperia to come up with such a crappy phone. what a waste of money!
hi friend i planned to buy xperia L plz sugges to buy it or not plzzzz..i already buy xperia miro but its hanging so i planed to buy xperia L plz frnd
