Neo L not switching on.. plz help
Ashraf343
My cell got switched off due to low battery and now its not powering on, no logo nothing appears only a red light comes while charging. i am trying to repair it using update service but after installation is complete again the same issue... plz help
12 REPLIES 12
Ashraf343
Hi Uliwolly,
Thanks for the response, will do that before i would like to tell my problem i am facing now..
I tried installing the software using update manager and now when i connect the mobile for charging a green light is on. before installing it use to be red light..
What does green light mean..?
Thanks!
did SUS work? were you able to run SUS and repair/update your phone?
Ashraf343
Yes i have used Sony Update Service and was able to successfull install it. but later as per the instructions i removed the cable and turned on my cell phone.. facing the same issue again. it just vibrates and doesnt respond..
you have to take your phone to a Sony repair center
Ashraf343
Hi Uliwooly,
The problem here is they are not accepting my cell for repairing  here in india. as this mobile is purchased outside india..
Could please tell me.. what could be the problem with my cell phone.. will there be any hardware issue..?
or just a software issue, reloading could solve the problem..?
Thanks!
Ashraf343
And can i try flashing it using Xperia Flash tool
you can try flashtool but this seem odd
Ashraf343
hmmmm... will try with using flashtool and let you the result.. thanks for help
