My cell got switched off due to low battery and now its not powering on, no logo nothing appears only a red light comes while charging. i am trying to repair it using update service but after installation is complete again the same issue... plz help
keep us updated
You are not the only one who had these problems. I had the very same issue as you, spent hours to figure out what to do, pc companion, sony update..and Flashtool did not work for me.The problem actually came from the Power IC on the PCB. On a 3 months old phone. And it's impossible to find the spare parts unless you find a broken phone you can buy..I'm still looking for one after 2 months. Good luck
facing same issue , no solution yet
plz help me if u found some solution.
