Keypad lock on Spiro?
How do I get the keypad to lock on my Spiro? When I close it up the keys below the screen still work, and I don't want to be accidentally calling people... how do I make them lock?
Probably a really dumb question, but I'm completely confused.
3 REPLIES 3
Dr_Chris
Champion
Main menu--Settings--General--Security-Automatic keylock--select on
I've tried that, but it doesn't do anything... It still does things when I press the buttons when it's on standby...
EDIT: just did a master reset and tried it again, working now. Thanks for your help. Slightly_smiling_Face
Dr_Chris
Champion
That's great! Tried it on my W995 and it doesn't work, but don't use it anyway as I rely on the screen lock when the slider is down.Good to know that a master reset can fix the problem though.
