I have a big problem , any help ?
my w205 was working fine , till i found some water on its battery , i don't know where it came from , however , i dried the phone and the battery , but the phone started not to work fine after that , the battery started to be hot after a little time and displays a message not to use the phone and battery and calling the callcenter and other problems , so i bought a new battery , all the problems ended , but now when i charge my phone it empties its charge after a little time , why is the new battery so weak ? or there might be a problem in the phone itself from the water story ? before the water problems the old battery was strong , what should i do ? the new battery is very new and very weak , anyone can help ?
Dr_Chris
Champion
Charge the new battery for a few hours and see if it holds its charge.It's also probably a good idea to run the software update service on your phone.However, bear in mind that the phone may have water damage which isn't something that service centres like dealing with.
