VGN-SZ5VWN/X motion eye driver
Rowanpeake
I have just bought the VGN-SZ5VWN/X , and running vista seems to be a nighmare. cant get the webcam to work at all, i have removed the driver and looking for one that will work through vista?? my audio driver had the same problem,
Blencogo
Hi Rowanpeake and welcome.
The camera driver is universal for both Vista and XP. I would reinstall it as there is not another available. You will find a copy in C:\Drivers\Camera or you can download the Original Driver Package for your model from here: -
http://support.vaio.sony.co.uk/downloads/updates/updates.asp?site=voe_en_GB_cons&c=0&s=VGN-SZ&m=2659
What are you trying to do with the camera? You cannot open the Camera Utility in Vista as you could in XP - you have to set the camera up in Skype or whatever IM program you use.
To capture Video Clips or Stills, you need to open the Vaio Camera Capture Utility in 'All Programs'.
:thinking:
