tv tuner for PCV-V1G
rubyred52
hello
this seems to be an old issue but hopefully someone can help me
i have an old pcv-v1/g but when i try to set up tv on it i get an error message saying
CHSETUP:6003
Fail IInputInfo::GetAvailableBaseChannel()function.(0x80004005)
i cannot set broadcast area
please help
7 REPLIES 7
Blencogo
When did the TV function last work properly?  It will only work in analogue broadcast areas - where do you live?
What aeriel do you have connected?
Are you using the original XP Operating System and is GigaPocket installed and working?
:thinking:
rubyred52
thanks blencogo for replying
i've bought the PC in used condition . original windows XP and giga pocket are installed and working.
about the signal , i could watch TV some time back on my other PC (vaio vgc-v3s with analogue tuner)
also i still get signals on another pc with a digital tuner
Blencogo
It sounds like the analogue signal may have been turned off in your area as your V3S and your V1G both can't get analogue channels.
Which TV Transmitter mast do you get signals from?
:thinking:
Blencogo
Presumably you use the Crystal Palace transmitter, which does not go 'digital only' until April this year.
Even if you could get the V1G working, you will only get a short period of use as it would stop forever in April 2012 so it may not be worth too much effort.
I see there is a software update for the TV Tuner on the download site here: -
http://www.sony.co.uk/support/en/product/PCV-V1_G/updates
You need the 'Sony RealTime MPEG Encoder Board Driver' which you will find under Latest Downloads -> Windows XP -> Drivers.  It may be worth installing this as a last effort.
A cheap USB digital tuner could be the best way forward.
:thinking:
rubyred52
what i meant about the v3s is that i could watch tv on it sometime back when i had it ( about a month ago)
i've sold it now so can't check again but it definitely worked then.
also i live in middlesex if that can help finding the transmitter
Message was edited by: -Cass-
Edited for personal information
quemans
original windows XP and giga pocket are installed and working.http://www.depin.info/g.gif
rubyred52
thanks blencogo
did what you suggested
bought a usb tuner and now am watching tv
