Replacement DVD drive for VGN-TX1XP/B...?
slicendice73
Hi everyone
I have a VGN-TX1XP/B and the DVD drive has recently stopped working (it's done a good few years of service so I guess I can't complain!). As everything else seems to be fine, I'd like to replace the DVD drive but I'm not sure what the part/model number is (or even if it's possible to buy such a part any more)...can anyone help me out?
Many thanks
Ed
Blencogo
Hi Ed and welcome.
I am not sure what drive you have in your TX - it's probably a Matshita UJ832 - but these units are fairly standard these days and you may find that any slimline ODD will do.
Best to remove your old drive and then buy one with the same form factor.  The re-fitting of the external bezel may be your biggest problem so it may be an advantage to look for a Panasonic drive as they made the original Matshita OEM drives.
If you need help to remove the old drive, PM me your email address and I will send you what help I can find.
:wink:
