Still having problems with Wireless Switch Utility
StuMcBill
Hi
After updating my Wireless Drivers using the Vaio-Link website, and installing the new version of "Wireless Switch Setting Utility" (which is supposed to work with the new drivers), it still doesn't work!
I have a Sony Vaio VGN-S5XP/B laptop computer with WindowsXP Professional.
Can anyone think of anything I can try to get this to work??
If you need any more info, please let me know!
Stewart
3 REPLIES 3
tonybeard
Make sure you have the downloaded driver in a place you can locate it. :wink: Then go to My computer right click and then /Properties/Hardware/Device Manager and in the network adapters tree right click and install the driver manually through the prompts.
StuMcBill
I have installed the Wireless Drivers, but the Switch Setting Utility still doesnt work when I start it!!
Thalamus.
Champion
Hi Stewart,
Does a system restore to a point before you installed the update allow you to connect to the internet..?
