I'm experiencing very slow wireless data transfer rates between my Vaio FS285M and Netgear DG834G router. The signal strength is consistently excellent, yet the speed ranges between 1Mbps and 54Mbps. Having investigated the problem within these forums, I thought i had found the solution by changing the power management setting from default to highest. However, this has not solved my problem. Can anybody please offer advice on how i may improve this very frustrating problem?
Hi jay_gob! Many thanks for taking the time to answer my query. I have used your tips, and so far so good! My data rate consistently sits at 24 Mbps or more. So once again Thankyou for the top tips!:smileygrin:
Hi jay_gob! Many thanks for taking the time to answer my query. I have used your tips, and so far so good! My data rate consistently sits at 24 Mbps or more. So once again Thankyou for the top tips!biggrin
