problem w/h my club vaio
merve
Hi all, from the very beginning my club vaio application does not work, it takes such a long time during log-in and it is never openned. i could not erase it from the start up programs. Does anybody help me how can I get rid of it? thx...
2 REPLIES 2
Blencogo
Hi merve and welcome to Club Vaio.
If you click on "NEWS" at the top of this page, you will find a link to a patch which should fix the problem.
If all else fails, go to Task Scheduler and disable it from running.
:wink:
blforde
Hi
I have a similar problem with my week old c2s. At start up the whole system just grinds to a virtual halt.
I have attempted suggestion one, with no success, only the following message;
'The application is missing the required file'
Anyone have a similar problem?
Regards
Benny
