Need a drivers for PCG-2B1P
profile.country.ru_UA.title
apyafg_
Need a drivers for Vaio PCG-2B1P, especially recent NVIDIA driver. Please help if you can! The Sony support section unfortunately does not recognise this model, so no drivers provided on support :slight_frown:
Thanks.
3 REPLIES 3
Blencogo
Hi apyafg and welcome.
The reason you cannot find this model on the Sony website is because PCG-2B1P is not a valid model.  It is possibly a chassis model but these can be shared by many models.
Look for another model number on the screen surround or above the keyboard.  If you find a genuine model name we may be able to help.
If it is a desktop computer the correct model may start PCV- or VGC-
Blencogo
A bit of further research shows that the PCG-2B1M chassis is used for the model with the correct name of VGX-TP2S.
Look for a model name VGX-TPxx and you will be able to find downloads available on the Sony website.
apyafg_
Thank you very much, it really helped !
