memory upgrade for XL201
danf_42
I'd like to upgrade the ram in my XL201, only the tech specs say to use 677 DDR2. Looking online there are 2 versions PC5300 and PC5400. Looking inside the XL201 it looks like it has PC5300 in there already.
What's the difference and could I put PC5400 ram in there with PC5300?
16 REPLIES 16
Thalamus.
Champion
Hi danf_42,
Have a look at Cruical.com several members have bought extra RAM from crucial and another benefit from buying from Crucial is there memory compatibility guarantee. :wink:
Also you may find this guide, from Sony, on how to upgrade your Vaio's memory of interest.. :slight_smile:
danf_42
Hi Thalamus, thanks for the reply.
I had a look at that guide the other day and it just says to use DIMM - 667Mhz (DDR2).
The problem I'm having is there is 2 types of DIMM - 667Mhz (DDR2). There is PC5300 and PC5400 and I'm not sure what the difference is and if I can use either type.
Thalamus.
Champion
Hi danf_42
As far as I am aware DDR2-5400 and DDR2-5300 are exactly the same, I think it's just down to manufacturers marketing.. :thinking:
As Crucial don't seem list the PC5400, to be on the safe side I would stick to the DDR2 PC5300 that Crucial supply as they offer a money back guarantee.. :wink:
danf_42
Thanks Thalamus :slight_smile: I usually go for Corsair ram, but they have mainly pc5400. So I might have to give the Crucial ram a go.
Thalamus.
Champion
You're welcome.. :slight_smile:
Blencogo
Hi danf_42,
I would give Corsair a miss if I were you - we have had some compatibility problems over the years. Not in every case but frequently enough to avoid them. Vaios seem to only recognise 50% of the installed RAM when using Corsair memory.
:wink:
danf_42
Thanks for the warning Blencogo. I think Crucial ram it is then :slight_smile:
ITTroll
I used Crucial for my upgrade:
2 x Crucial 512MB DDR2 PC2-5300/667MHz CL5 1.8V Unbuffered 240 Pin
Ebuyer QuickFind: 119258
Works a treat!
danf_42
Excellent, thanks IT Troll. Always good to hear from someone who's already done it :slight_smile:
