hi everybody!
i've got a small problem with my notebook. i'm using Vista and everytime when i plug my headphones to my vaio the music is playing via speakers not headphones. how to fix it ? regards
Hi luque23,
Open Control Panel and then Sound. Make sure that Speakers/Headphones is set as the default device.
If it is then I suspect that it is a hardware problem as the switching between speakers and Headphones/external speakers is mechanically controlled within the jack plug socket.
thanks mate. it works
