Function Key
CarlMichaelJwtt
Function Key
I have a intermittant problem with the fn key, when I use it with the F3&F4 keys the on screen bar does not always display? can any one explain why,I would add the sound does go up and down even when the display does not work. Regards Carl
10 REPLIES 10
Thalamus.
Champion
Hi Carl,
is there a pattern as to when you have this problem, ie after waking from hibernate.?
CarlMichaelJwtt
Hi Carl,
CarlMichaelJwtt
Hi Thalmas I have not niced any pattern, its not working now, I do not use Hibernate. Carl
Thalamus.
Champion
You could try the following..
Can't remember what model Vaio you have. :thinking:
Download the following utilities for your Vaio from Vaio-Link, (may be original Preinstalled Utilities, if so you'll need to extract the files first)
Then install the following, in order.
1 Sony Utilities
2 Sony Shared Library
3 Vaio Event Service
Once completed then re-boot your Vaio.
You may have to do this more than once..
CarlMichaelJwtt
1 Sony Utilities
CarlMichaelJwtt
,Thank you my Vaio model is VGN-N21M Many thanks Thalamus I will give your suggestion ago if I can perform the task.Carl
CarlMichaelJwtt
Sorry Thalamus not worked, thanks for your help. Carl
Thalamus.
Champion
Are the function keys working.?
CarlMichaelJwtt
Function key not working on sound appears to work on Brightnes,but no on screen display???
