Does anyone know how to turn on and off the Fn function that makes the u,i,o,p,j,k,l,m keys turn into numbers please? I've done it by accident and now i can't type without holding down the fn key - it's really annoying!
Than2s!
Hi quetzal_paradise,
press the Num Lk key (top right) once should turn the keys back to the correct letters..
Thank you Thalamus!!
That was so quick & simple I feel silly for getting stuck 😛
Have a good day then!!
You're welcome..
It's only quick an simple if you know how, you're not the first to ask the question and I'm sure you wont be the last..
