adobe flash player help
marjarma
Hello
For some reason i can't use my windwows media player or see videos at my space or you tube or anywhere for that matter,as it said i either had javascript turned off or i needed the new adobe flash player 9.
I have no idea how to turn it on as i never turned it off and i have downloaded the new player and still it doesn't work.
Does anyone have any ideas?.
2 REPLIES 2
Blencogo
Try downloading and installing the 'Complete Standalone Installer' version of Flash Player 9.0.28.0
http://www.softwarepatch.com/internet/flash.html
There does seem to be a problem with incomplete installation with some other downloads.
:wink:
marjarma
Hi
I tried that and i still can't see a player.
