Is Sony soundbar HT-CT290 compatible with Sony Bravia WD756BULEDHD 32 inch tv?
Hi nonuffink,
You would need to check whether your TV has an HDMI terminal that supports Audio Return Channel (ARC). The HDMI input terminal that supports ARC will be labeled ARC.
You can find more help details here.
Thanks,
Sean Mc
