I have just moved into a new home and want to disconnect the plug cable from the TV in order to feed the cable through the hole in the top of a cupboard down to the plug socket. However the plug is moulded on and the cable doesn't seem to attach easily from the TV end.
Any ideas?
Many thanks, Cath
well theres only really 2 options here, one chop off the plug and fit a new one or two use a short extension lead and remove the plug from that, at least that way you dont chop up the original lead.
Thanks - I feared that was the answer!
