I'm sorry to hear that you're not happy with the display in your T2 Ultra
The specification i have for the phone doesn't mention any brand for the display but all displays used in this model are 6" IPS displays with Triluminos Display for Mobile and Mobile Bravia Engine 2 which meet our strict quality requirements. But when comparing two phones of the same model it's normal that there may be small differences in color and brightness.
What you can try is to adjust the white balance and brightness under Settings -> Display and if you have any display protector this may also affect the color and brightness.
If you suspect there's something wrong with your phone i recommend that you contact your local support team or a service location to have this checked.
I'm glad to hear that
