I am so angry with my phone after having upgraded to 9.2.a.2.5 from a lower lever of 4.3. On the previous version it was quite stable. Now it powers off a lot, for no obvious reason. It seems to happen more often later in the day, when battery power gets lower. I have tried the following, but nothing seems to help:
One strange thing about the powering off is, that I lose my language setting from Swedish and it gets set to English. Funny?
Regards / Matz_E
hi guys, buy a new battery and this problem will be solved. i had same problems few days ago , and with new battery all problems gone! im glad to use my xperia v like i done it before update
One more thing. When it gets unstable like today, it powers off after I have entered the SIM pin, but before unlocking the phone. It often does that repeatedly. Battery was today about half charged. I've had this happen 3-4 times in a row, and the way to circumvent it is to start charing the battery. Then it works like it should.
So, I have ended up with a phone connected with a wire to the wall outlet again, just like in the old days. Mobility may be a thing I have to sacrifice:smileysmileywink:
I wonder if it is hard- or software. Since it started happening after having upgraded to 9.2.A.2.5, I still suspect it is the OS, not the hardware.
Still no comments? Anybody!
Regards / Matz_E
Hello!
I'd like to confirm the same problem. If battery drop below 50%, every heavy battery draining program that I run reboots the phone, until I recharge.
Problem seems to be highest when useing heavy draining progrmas, like games, or GPS or even Camera.
Before 9.2.A.2.5 update, I didnt face this problem.
First I thought that the OTA got somehow badly installed, but I did a clean SUS recovery and the problem continued.
So hopefully this problem gets fixed in the next update.
Yes, I agree, the risk of having an unexpected power off is greater if I use the GPS and the camera.
Regards / Matz_e
I have a new battery on its way in the mail. I will get back to the forum, when I have used it for a while.
Regards / Matz_E
I'd like to confirm, that it seems to be the battery.
I downgraded my phone to 4.1.2 version and the problem was still there.
Just ordered a new battery. 🙂
Hi, sorry to give you the final answer so late. It is now 3 months since I ordered a new battery, but it took 2 months to realize, that it had been lost in the mail. Ordered another (standard Sony battery), and have used it for soon a month. And everything works like a charm! So my problem was that the battery could not supply enough current. After changing batteries, the GPS in the phone is better - but not good. It still takes a long time for it to find its sattelites.
Regards / Matz_E
