I have just updated my Xperia U to ICS and noticed that the liveware manager hasn't been replaced with smart connect. I have been using smart connect on my Xperia Neo for some time now and there are some functionality that is lacking in the liveware manager app which I use. Will the Xperia U be given an upgrade to smart connect?
Yes, be ready for a google play update notification soon. Or visit google play and log in.
I have Smart Connect there. I flashed with FR version...
