This thread is for T2 Ultra users to report any bugs after lollipop, before you do so, try the following:
If your battery drain faster or the phone seems slower or apps are crashing, it'll be wise to reinstall lollipop with PCC
even better if you update deleting all the apps and settings, keep in mind that by doing so, you can not use the backup & restore app to restore anything.
Bridge (for Mac)
This thread it's not to ask when is the update going to be released in your country and/or carrier network. you can read about it here
i really wonder is tester and devloper really checking updates before releasing.. this update is full of bugs... sony please look into this.
Facts About my Handset : Xperia™ T2 Ultra dual D5322 Android Version 5.0.2 SOFTWARE: 19.3.A.0.470 (Latest) I am facing the following issues in using my above Phone, Please suggest solution or software patch to fix these problem, Your India helpline does not provide quality help nor they are capable of understanding the exact concerns most of the time and repeat question in answer or always suggest Resetting the phone t2 ultra dual after recent update to lollipop update 5.0.2 Lollipop ... 1. Notification tone in built in phone is getting distorted sound at the time of playing the sound at the moment notification or Calendar Event arrives on the reminder 2. Contact Mobile number stored in Google contacts is shown as Work or Home Number in Call Logs. 3. Not able to select contact ringtone from my songs or tone collection of my choice , but forced to chose from Xperia supplied inbuilt tone bank. 4. I am not using Google hangout but my phone roff and display that hangout has stopped working unfortunately Hangouts has stopped." This message keeps flashing rat Random intervals on screen display and goes off itself or press of Ok. 5. Message saved as draft sometime does not open again after saving as draft. I don't know what to do anymore. I tried using Reset Phone and everything being told on helpline but nothing has worked to solve the above. PLEASE HELP !
Can anybody poin out the specific bug-fixes in respect of firmware update
for Xperia C3 and T2 Ultra (Build number 19.3.A.0.472) ?
