Xperia T2 Ultra / T2 Ultra Dual Lollipop issues and feedback
This thread is for T2 Ultra users to report any bugs after lollipop, before you do so, try the following:
If your battery drain faster or the phone seems slower or apps are crashing, it'll be wise to reinstall lollipop with PCC
even better if you update deleting all the apps and settings, keep in mind that by doing so, you can not use the backup & restore app to restore anything.
PC Companion (PCC)
Bridge (for Mac)
This thread it's not to ask when is the update going to be released in your country and/or carrier network. you can read about it here
http://talk.sonymobile.com/t5/Software-Updates/Android-5-0-When-are-we-getting-Lollipop-Which-Xperia...
213 REPLIES 213
Samuel1
Hero
Unfortunately we can't provide any specific changelogs.
Best regards,
Ksharma
after update 472 some bugs fixed.
s4alon
Camera seems better for both., especially front one.
Noise different is pretty amazing for me.
And for the rear cam., auto exposure work now when focussing at different light condition. At high ISO noise didn't appear much like before for me.
How about anyone ?
Rickard
Master
@s4alon wrote:
When I turn on the [HDR] feature and try to snap picture it really something I don't really want to have at my phone.
the feature is completely broken, the image got much higher noise level and everything turn greenish and yellowish.
I mean HDR supposed to give good image when there's back light right ?
can u confirm this ?
I received more information about this and i'm afraid the front camera doesn't support HDR which is why it doesn't work properly. The option to enable it should not be there and this has been highlighted to the project for correction.
s4alon
@RIckard
Can I know where's the wifi by location setting moved to., the feature at lollipop that makes the phone turn on the wifi automatically at saved location.
and also, after the, 472 update there's still batter saver toogle at the battery setting and, low battery mode at the power saver menu.
aren't both of it the same feature ?
also at this new update SONY not yet including the new "Clear all" button at recent apps.
anyway it's great update.
phone feels more stable than usual, no random lag. better battery and camera too.
I tried some picture at 1600 ISO and the grain is still at tolerable level.
also the auto focus at manual mode seems to have auto exposure like other apps.
might wait for the camera API 2 which bring the full manual control too I hope Grinning_Face
Ksharma
Is android phones safe for security reasons. I thinks no. Because if I have put a pattern lock on my phone anyone can switc off it without opening lock. Sony should provide some security for it that in case anyone's phone misplaced the same cannot be switched off by the founder or thief.
Saravanan_B
I am unable to update Build number 19.3.A.0.472 through pc, after automatic switched off Sony connect showing please wait for 1 Hr but not was processes or thrown error, Pls some assist on this
Khan31
After rolling on lolipop ok google from any screen detection is lost
profile.country.RO.title
_alexdon_
You can enable that from google settings.
alexdon
anthonykitmcinn
One of the reasons I loved my T2 Ultra is due to the 639 nits of brightness.
After having updated to Lollipop via Sony PC Companion the screen bright is way low. I went into settings and placed it at full max brightness like I have always had it set and its just not the same anymore.
Its currently the same brightness of my broken Z Ultra.
I hope ths gets fixed or I will have to move on to a different phone.
