Xperia T2 Ultra / T2 Ultra Dual Lollipop issues and feedback
This thread is for T2 Ultra users to report any bugs after lollipop, before you do so, try the following:
If your battery drain faster or the phone seems slower or apps are crashing, it'll be wise to reinstall lollipop with PCC
even better if you update deleting all the apps and settings, keep in mind that by doing so, you can not use the backup & restore app to restore anything.
PC Companion (PCC)
Bridge (for Mac)
This thread it's not to ask when is the update going to be released in your country and/or carrier network. you can read about it here
http://talk.sonymobile.com/t5/Software-Updates/Android-5-0-When-are-we-getting-Lollipop-Which-Xperia...
213 REPLIES 213
s4alon
And why there's no advanced camera setting ?
I can be made available right ?
namu
Lolipop version just.. Dam ruin the phone performance lagging, answering machine not working, it says could not save greeting while making on answering machine any ideas..pls
s4alon
Day 3 using the phone., I think there's indeed a performance problem.
Sometimes even after restarting the phone the phone having a slow time at.openning apps. And it's totally random.
Sometimes it lag so much and freeze for a while.
Maybe performance improvement needed at future updates.
s4alon
@uliwooly
@Rickard
so can any of you confirm that after the lollipop update the front camera really got the [HDR] feature toggle... ?
because when I tried to turn it on it really like some mistake.
When I turn on the [HDR] feature and try to snap picture it really something I don't really want to have at my phone.
the feature is completely broken, the image got much higher noise level and everything turn greenish and yellowish.
I mean HDR supposed to give good image when there's back light right ?
can u confirm this ?
Thank You.
ANAS2
Hello All
i'm very sad to use the latest update ( Lollipop )
the update have a some bugs issue
slow, lag, multitasking is very bad
i go back to downgrade and use KitKat
we hope to fix all bugs if Sony want to put a new version from Lollipop .
Ksharma
I am also facing the problem when I used flashback the apps installed in sd card are not working
amit_rocking87
This version is really useless.. Tried all device is still very slow.. Guess ram is less on this device and that is issue
@Crisgdo
Just like the C3 the T2 Ultra has 1GB of RAM, that could be the reason why it lacks multi-user, Someone from Sony already is investigating on this for the C3, most likely it'll be the same reasoning.
Crisgdo
that's funny. haha Because moto G has the same 1GB of ram.
@Crisgdo
Let's wait for an official statement.
