This thread is for T2 Ultra users to report any bugs after lollipop, before you do so, try the following:
If your battery drain faster or the phone seems slower or apps are crashing, it'll be wise to reinstall lollipop with PCC
even better if you update deleting all the apps and settings, keep in mind that by doing so, you can not use the backup & restore app to restore anything.
Bridge (for Mac)
This thread it's not to ask when is the update going to be released in your country and/or carrier network. you can read about it here
I am using a Sony Xperia T2 ultra dual phone in India
Having problem with wifi connection
The Wifi Connection automatically drops down after using it for some time
Also the phone lags a lot and Some apps become unresponsive
The web Surfing has also become a disaster
Is there any future updates in plan for this phone??
Do you have any antivirus or taskilers? are you using a third party phone app?
Replying to this question
There r 2 such apps installed
one is avg pro and other one is 360 security
What should i do to ncrease speed of my phone
Battery is below 20% and low battery mode is not activating.
And one more thing., I got line messenger and using it often.
Ussualy I never close it. Just put it at recent apps.
Sometimes it's like being killed by system.
No notification showing., but when I open it again the notification just started showing.
Is it apps related or different thing.
Already repaired and do clean installation before.
Is there any other method to improve the speed of device
Also u haven't suggested for the automatic downgradation and offing of the wifi
Do u Have any idea on is There a Stable version Of lollipop being developed by sony?
NO multi-user, why?
