Does the xperia t2 ultra dual support camera functions like manual shutter speed, manual focus, manual white balance, manual aperture setting, manual iso and raw photo format? I heard that android lollipop support the above mentioned camera features. But when i download the manual camera and manual camera compatibility app nothing works. So why do Sony limits the camera functions? Is there anyway i can enable the features?
Unfortunately those advanced manual camera features are not available in Xperia Cameras at the moment, there's a lready a big discussion about the Camera2 API on the forums so I suggest that you join it:
/t5/Software-Updates/Camera2-API/m-p/974742
You can also revise Xperia T2 Ultra White Paper for full list of your camera capabilities.
