My Xperia TX/Lt29i doesn't charge or turns on need help!!
xenontype42
My Xperia, I assumed had a battery problem when I charged my phone, it drained the battery. so I switched it out... Now it doesn't charge. It doesn't turn on, and it has no LED notification to say it's charging... Please Help!!!
Hampus
Champion
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
I suggest that you remove the battery and insert it again. Without powering on the phone, connect it to the charger via wall socket and let it charge for 1-2 hours. If the battery is completely flat, it can take a longer time before the phone indicates charging.
If there are no reaction after this, I would suggest that you try another charger and if possible another battery to exclude problems related to your accessories.
3 REPLIES 3
Hampus
Champion
xenontype42
Thanks alot, I tried it the light came on but the problem still persists so I sent the phone to the shop.
raminjj
buddy at the end what did u do to fix problem?
