I am using Xperia ray since February 2012. About one year I had no problems. But then some problems started to appear, such as, sometimes the mobile phone cannot read the SD card and the battery drops from 40% suddenly to flat. Now my main question is that "Contacts" drains my battery a lot (right now 33%). How can fix it? Yes, I am using synchronization of my contacts with my gmail account. If I turn the sync off, will the problem be solved? Please, help me.
Phone specs:
Model: ST18i
OS: 2.3.4
Kernel: 2.6.32.9-perf
SEMCUser@SEMCHost#1
Build no: 4.0.2.A.0.62
Turn off syncing and only turn it on/sync when you add new contacts, same goes for facebook, twitter, etc
Thank you, uliwooly. I'll try it.
