Yesterday i was trying to access contacts on my phone and was flashing that "Not responsing", so i tried to reboot and afterthat it has not stopped rebooting.
What is the main reason ?
My phone is still under warrenty. I am a technical person and have a knowledge of computer softwares. Should i update it with SUS or should i give in Sony service centre?
Will my warrenty void if some installation goes wrong?
What are the steps for SUS?
Is there any other reason or any other way to make it work?
Pinank Shah
Hi RV,
i tried using SUS and it worked for me. you should have given a try for that.
i am a technical guy so was succeed in doing that. my email is pinank.mails@gmail.com. if you have any problem and something is in my reach, then sure will help you.
Its funny sometimes people in sony center doesn't know the solutions to a certain problem
I am facing this problem from two days & have used SUS, thanks for the info
Reinstall,it should fix your problem.
guy i have a big problem ..... but i didn't know how to get a solution for this cp autorestart.. every i turn on my cp it will restart every2-3secimso annoying about this i can't use it becoz this prblem.... the first is i reset the and create a google acc and then download a game after downloading it the playstore is not working thats why i tried to force shutdown it but i see a update before i shutdown it but i ignore it then when i turn on it now my cp are always auto restart after that ...did anyone resolve it please help i dont know to do it please help i need it truely
