X8 roadsync error
X8 roadsync error
Hi i just bought my x8 few months ago and just today i had a problem i cant used it screens showing "roadsync error cannot read internal database try to restart unit if problem persist  uninstall and install, i already had tried restating but failure still shows about installing and uninstalling i dont know how to do it. please help me
gwhispererz
Champion
Hi, suggest Software Repair phone with PC Companion, it should fix the problem.
Be aware that this process will erase phone data completely (SD Card not affected), remember to backup.
2 REPLIES 2
gwhispererz
Champion
Bellvania
hi . I currently had this kind of problem too.. any tips for me? Slightly_frowning_Face
