NFC
charlest
NFC
Hi everyone,
Do I have to install a NFC app from Sony in order to use the NFC features?
3xperia
Hi, Charlest
No, you don't have to. All you have to do is just turn it ON, and other devices you want to connect with your phone must have the same feature.
Settings > More > NFC.
Hope this helps
2 REPLIES 2
3xperia
Hi, Charlest
Hope this helps
charlest
Thanks for your reply.
