hi my wife have sony xapria t i want to know when be avilable upgrade to 4.1 from 4.0 in isreal ?
you are not going to find specific dates for the release date, as it varies per region/network.
if your phone is or was locked to a carrier/network branded, it will be up to the, the network, to approve and release the update.
you have 2 options
1) wait for the update
or
2) manually update your phone (flashtool)
if you want to manually update your phone
How to manually update, downgrade, root 2012 Xperias
I have the Xperia T and live in Israel and it's been updated to 4.1.2 long ago. I bought it from the original importer so that might affect the availability of the update. if it hasn't been updated yet i would check with the shop from whom you bought the phone...
Nadav
