Can i use this method for Sony Xperia Z3, because i see the same stuff like little scratch on the lens that makes my pictures not that sharp, and look unfocused.
@interference
I'm not sure, since you have different type phone. I suggest you be careful, since Xperia SP has 2 type lens, one with coating layer, and one other with not coating layer. If you try to peel lens without coating layer, it can more damage the lens surface.
OMG!! Thanks a ton! It worked.. Xperia Z1
I had taken it to the Sony Service Center. And those guys said it will cost me around 3000Rs (50$) and a weeks time to fix it.. You just saved my time and money!!!
Yes, I had problem of blur image, i was disappointed, i thought to take to service centre, I had purchased only 4 months before,
i came across this post, did same thing, i put alchol and started scratching the lens covering the lens got cleared, glass was clear crystal, then i came to know some coating was there on the glass, now its become so crystal clear, photos are superb, thanks for the post which helped me lot.
thanks dude i did thas scratching again with alcohol thing and now my sony z1 camera works just fine and pics back to clear
thanks again buddy :smileysmileywink::smileysmileywink::smileylove:
Hello ..
I have also encounter problem on my Xperia XA i bought it last Nov 2016 then after a month, i had noticed the blurry and foggy images from the main camera of my phone. i think it was scratches also in the camera lens.
i already tried to wipe the lens using cloth with alcohol but nothing was changed.
Do you have other solution for Xperia XA?
Appreciate a lot your reponse.
thanks..
