awesome man.....!!!! thanks a lot... I thought my camera is gone...but after using your remedy it worked out perfectly fine for me and my camera is working as good as it used to be....thank you very much...you saved my phone !!!
ahhh camera is perfect now! I rubbed alcohol on the len and its clear now! Thank you
Is it possible to scartches again after aplling this method.
Thank you for this, i was wondering why my camera had problems with focusing and photos looked really blurred and "glowy" like it had some kind of filter on. I was thinking it was because of the "scratches" on the lens and gave up, but thank goodness i found this thread with the solution, here's some pictures taken today before and after cleaning with rubbing alcohol:
Hope it stays that way for a while, thanks again! Now if i had only found this sooner...
Someone knows if this fix is usefull for Xperia M2 also?
Im not able to peel off the coating on the lens...
maybe in my M2 there's no coating but is just the lens blue... (?)
After almost 2 years since i bought my Xperia SP, I finally decided to peel the coating on the len(s) because of the blurry pictures.
Pictures are now sharp but still noisy which doesn't have anything to do with the lens coating.
Thanks for the tip! 🙂
I've just tried your method, and it works wonderfully. I feel like I have new cam. Thank you so much.
Yessssssssssss!!! this works , I had same issue with my sp and after cleaning lens its all clear. thanks ...
