Sony Xperia S Update problem
njm
i cant update my xperia s to 6.2.B.1.96,while trying to update it with the Sony PC Companion, when my phone shuts down pc (running w8)shows a warning USB device not recognized.Pls give a quick solution.
You need a 2.0 USB port
Don't forget to give Kudos (Click on the half star + )
11 REPLIES 11
This should be interesting for you to know
http://www.sonymobile.com/global-en/tools/pc-companion/
  • 1 available USB 2.0 port and USB cable
  • Microsoft® Windows XP™ SP3 (32 bit), Vista (32/64 bit) or Windows 7 (32/64 bit) or Windows 8 (32/64 bit)*
http://talk.sonymobile.com/t5/PC-Mac-Software/PC-suddenly-not-recognising-Xperia-Go/m-p/375431#M285
Sony Xperia Support
Sam
Re: PC suddenly not recognising Xperia Go
Uliwooly's option is quite likely correct, however before going down that path please try this:
To solve the issue, open Device Manager on your computer to reinstall the driver for your device while your device is connected with your PC via a USB cable.
Microsoft Windows Vista and 7 users
To open Device manager on your computer
Click on the Start button.
In the Search box, type device manager, and then press enter. You should see something similar to the below example.
Microsoft Windows 8 users
Method 1
Click Windows Key + X to open the Start Menu.
Select Device Manager from the Start Menu.
Method 2
Click the Desktop Tile to open the Desktop.
Click >> at the bottom right of the taskbar.
Select Control Panel from the Menu.
Select Device Manager from the list of control panel items.
Note: If you do not see the screen with the Device Manager option, click the View by drop-down menu and select Small icons.
Microsoft Windows XP and 2000 users
On the desktop, right-click on My Computer and click Properties.
In the System Properties window, click the Hardware tab.
In the Hardware, tab click the Device Manager button.
To reinstall the drivers for your device
Scroll down to the Universal Serial Bus controllers (USB section) of the Device Manager window.
Look for an MTP Device: Media Device, Unknown Device or any other reference to your phone. Click on this entry and choose "Uninstall" whilst leaving the device connected.
Wait a few minutes, and the computer will reinstall the drivers for the device.
Now, the phone is accessible via Computer/My Computer on your computer.
What are your thoughts about this forum? Let us know by doing this short survey.
njm
oh man thnx
Anytime
CliffyK
I tried updating my Xperia S to the latest update but an error occured during the update process and now I can't start my phone. An error symbol is being shown when I'm trying to switch on my phone.
profile.country.RO.title
_alexdon_
Try force restart(power button+volume up until the phone vibrates).
alexdon
Sam
Legend
Legend
If the advice above does not work, then please start the update process again exactly as before but without the phone connected and choose the "Repair" option when it is offered.
CliffyK
The phone isn't being detected via USB anymore. All it shows is a' triangular error and a phone' symbol when I'm trying to start it.
