Sony Xperia Ray Hard Reset
DeanWespa
Hello,
i have a problem since today that my handy is starting and when the Xperia logo comes , the animation of the logo froze and the complete handy is restarting over and over and over the same things: startup , sony logo , xperia animation , froze , restart.
over and over...
i want to make a hard reset but i cant because for "Sony PC Companion" i need to start the phone to the Lock Screen or get it in some Repair Mode idk.
I tried SEUS (sony pc update Service) but it updated and sayed its no longer supported.
what can i do? Thanks in advance.
@DeanWespa
The phone doesn't have to be on for PCC to work, just run PCC > support zone > follow the steps and leave the phone off.
PC Companion (PCC)
Bridge (for Mac)
5 REPLIES 5
@DeanWespa
PC Companion (PCC)
Bridge (for Mac)
Thommo
Performing a system repair using PC Companion - This will factory reset your phone and erase all data
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the on screen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
DeanWespa
thank u for the Fast Supply , i will try it out
DeanWespa
thank u soo much.
it worked.
hopefully someone will find this guide and it will help him out ^^
Excellent Slightly_smiling_Face
