Hello, i have a little problem on my xperia sp device, sometimes it lets me slide down the notification panel, sometimes it doesnt. I have reseted the phone and even an software update and didn't helped me.
Do you have a screen protector placed on your phone? You could also run a test via the Xperia diagnostics app to see if you have a digitizer issue
If Thommo's tip doesn't help, you should send in the phone to a service center for repair. Contact your local Xperia Support for more information.
Repair the phone with PCC and see if you experience the same issue again
Bridge (for Mac)
i did that and it doesnt work
Contact your local Xperia Care
Anytime
