hi
i'm using xperia j
how can i take screenshot?
tried the volume down + pwer button but failed..
pls assist..
thanks!
Hi, make sure you press and hold both power button and volume-down button together till you see the screenshot taken.
worked!
thanks a lot!
Welcome.
Thank you. I wanted to know also and it worked for me. Thanks
my phne xperia j was fallen down and it was stucked and my phne was asking some password what is that password
There is no password normally other than a password set by you for security reasons or maybe an app acting up.
its working hahaha thanks bro
