Quirky problem, the Screen Lock Sound is inactive, It's selected in the sounds menu as is haptic feedback and audible selection. All volumes are at max. I have rebooted and even done a setting reset Anyone any ideas?
whatever you downloaded..forget it
install this application..
i know main purpose is to hide all personal stuff but still download it , this acts as an audio manager too
so when you will open that application..
forget the pop up which says long press on audio manager to access hide it pro..
you will see 6 sounds option..
the 5th will be system sound.. make it full 7\7 and check your lock screen volume
Hi, I believe you should have tick Screen lock sounds. Just wondering .... did you select Silent mode?
screen lock sounds are ticked and phone is not in silent mode
How about other sounds? Any sound when you tap the app drawer?
no it doesn't
Not a good sign .... If there is completely no sound from phone (with any apps), would suggest you to send it to SE Service Centre to have it checked.
dial tones work on phone pad & haptic feedback works ok
not worth it... sound works on all app games - just the unlock slider - can live without it
Kind of weird though. Since there are still sound for other functions and apps, not sure if it is worth performing a Software Repair.
your phones music volume will be low or even to 0... so increase music volume in settings
