help! I haven't updated my sp, but my LED doesn't seem to be working at all - no notification light at all - any advice please??
thank you!
Check if you have the stamina mode activated in the phone. The led won't work in stamina mode. Go to setting > power management.
I do have stamina mode. but am sure it used to work in it. maybe it didn't! thanks for the advice though.. will try again!
thank you!
@cehails wrote:I do have stamina mode. but am sure it used to work in it. maybe it didn't! thanks for the advice though.. will try again!
thank you!
Hi, this has happened to my phone as well. It worked in stamina mode as I have had this selected since i bought it. When I did a software upgrade the LED notifications now only work when I am charging my phone which is really annoying as I liked to know if i have a missed message etc without having to turn my screen on.
Is there anything to do to fix this, I haven 't yet tried it withou stamina mode being on but I wondered if there is a resolution without having to turn that off.
Ta
I have the same problem, the led is only working when the phone is charging. My phone is up to date and now the led part is practically useless.
I will check back later, hoping to see a solution.
It's a known issue with .254. Until they fix it, enable stamina mode and install Illumination Bar
