remove auto backup!
Smruti
remove auto backup!
HOW TO REMOVE AUTO BACKUP PICTURES FROM XPERIA GALLARY FOLDER OF SONY TIPO MODEL ????
Rickard
Master
Then it's probably a folder that is being synchronized from the internet. Go to Settings -> Accounts & sync and check if synchronization of pictures is enabled for any account. If you look on that folder under Gallery i also suspect you have a small icon on it indicating what service it comes from.
6 REPLIES 6
Rickard
Master
I'm not sure what you mean by auto backup. Could you please elaborate?
Smruti
When I took few clicks from camera ..it went into auto backup folder into Xperia GALLARY..
How can I delete them ?
Rickard
Master
Sounds like you may have installed an app that backups your pictures to another folder.
When you open a picture in the gallery you can delete it from the menu shown when you press the menu button. You can also connect the phone to a computer and delete them from there.
If you want to stop the backup creation you need to check what apps you have installed and remove the app that's doing this.
Smruti
No..there is no option of deleting it ...that's y I asked here...
They dont provide any such option particularly for that folder
Rickard
Master
Smruti
Ok thank u
