hello, I have a problem and I wonder if you guys can help me
ok, this is my problem
I already updated my Xperia P for Jelly Bean version when I updated I activated Mode Stamina and Mode Low Battery, and the first time my phone I get the low battery doi these modes operate normally and after I loaded the battery he returned to vibrate normally more the second time he stopped vibrating and not came back, even after I loaded it stopped vibrating when I touch the button HOME, bACK and OPTIONS, and also does not vibrate more when the camera focuses to take the picture, it vibrates normal when I turn on, turn off or when DOING calls me
(sorry my english I'm Brazilian and I used google = P)
Sorry to hear that you have problem with the vibration. Because the fact that the vibration comes back from time to time I suggest that you repair the phone software with PC Companion to rule out any software problems.
http://www.sonymobile.com/update
In PC Companion, click start under Support Zone > start under Update phone > select Repair phone (in blue text).
Thanks!
i have same proble with my E4 after updating the software still same problem
