I missed a call from somebody today, and when I touched the "Phone" application to find out the time of the call, I got the following message:
"The application Contacts (process com.sonyericsson.android.social phonebook has stopped unexpectedly. Please try again."
I now get this message every time I attempt to use the phonebook, which basically means I can no longer make calls. I can still receive calls, and everything else seems to work okay.
Shutting down the phone and re-starting it did not fix the problem.
got the same problem but solved it on my own
here r the steps dude
open file manager there u will see the contents of your sd card. there is " up" or back button at the top of file manager. press it untill u reach in phone memory. here u will see the folders like acct, cache, config, Etc.
scroll down and find the "system" folder . then enter " app" folder . now find "SemcPhone.apk". just install it and there u go..... ta ta da......:) hapy endngz.........:D
